MattF
- South Yorkshire
I think that'd be the least of your worries by that time.![]()
Muppet.
Muppet.If you can't tell there are gradually less threads showing, & that it's loose, before the bolt drops out, you shouldn't be using tools.
You're not on the ball [plural] tonight....![]()
Hi folks, iv recently acquired a vice that has a solid base with a threaded hole in between the two bench mounting holes that i assume is just another fixing point as it has some threaded bar in it. Anyway the slide doesn't wind in or out, but if you undo the handle it will then pull open an same shut wise and once against something like a block of wood it does nip up and hold it. My question is, is this some sort of qr or is it more likely broken somewhere ?
Its jaws are aprox 6'' wide and its got a small square anvil type plate.
This is my other one that ive had for nearly 30 years and although its been stored for the last few im happy to see it back on a bench ready for use
And finally one that i inherited from my dad that he liberated from the docks iirc,anyway its in need if fixing and a resto if i ever get around to it. The vice does up to a certain point then slips' and wont go any tighter which id imagined to be thread related ? any thoughts on this or the yank one much appreciated.
Love the thread by the way,half way through so far an hooked lol
You were the one who enquired last year about it, as to whether I may be willing to part with it? Just making sure I'm not mixing you up with someone else. Don't want to risk upsetting anyone.![]()
@Gragson. Took some photo's last night, (now I've managed to find it), so that you can check it's what you need/want.
Look away from the wingnuts!
Had to offer it up - you knew I wouldeven has storage under the back - whats not to like
Works absolute treat. The base finish is so much nicer and practical than paint, what was the bees wax mix again?
Will get it fixed on properly tomorrow.
View attachment 256309 View attachment 256310 View attachment 256311
Isn't that swivel base on backwards?
