Gingle We are all in the same boat Messages 423 Location England uk Cambridge Oct 24, 2020 #1 so to save money, I made this to round of metal, or for other uses. One towing ball joint. Welded to thick metal bar. In the vice way you go 183068CB-1872-49CA-AFCF-DBD4CCC047F3.jpeg 262 KB · Views: 141
RonA specialist in repairing sealed for life equipment Messages 1,939 Location Stockton on Tees, UK Oct 24, 2020 #2 Hope you haven't patented the idea, mk2 could be in operation very shortly. RonA
Wallace Member Messages 7,766 Location Staines, Middlesex, England. Oct 24, 2020 #3 RonA said: Hope you haven't patented the idea, mk2 could be in operation very shortly. RonA Click to expand... There goes my Patent again. The first prototype was useless as it had a flat on the top!
Paul. Moderator Messages 7,051 Location Northampton. UK Oct 24, 2020 #4 Wallace said: it had a flat on the top! Click to expand... That's because its a 50mm ball, if you want a round top you need to look for an old 2" one
James1979 Member Messages 8,434 Location Orkney Oct 24, 2020 #5 Can you build it up and grind it round? Never tried welding one so not sure if that would work
A armalites Member Messages 6,694 Oct 24, 2020 #6 Absolutely ideal if you want to put your trailer in the vice to do some work on it. @nickk has a height adjustable one
N nickk Member Messages 5,706 Location Hay-on-wye Oct 24, 2020 #7 armalites said: Absolutely ideal if you want to put your trailer in the vice to do some work on it. @nickk has a height adjustable one Click to expand... No vice ,to get max height I used the forklift,see photos.
pedrobedro Man at Matalan Messages 13,099 Location CX near Chesterfield Oct 24, 2020 #8 Cut the top off and weld it into the tube and it will take a lot more hammer.
