MattF
- South Yorkshire
Just wondered if anyone had used one of these, & if they're any good, square to the piece etc.
https://www.ebay.co.uk/itm/264761988143
Use biscuits mainly. Easier.
Go with the one you linkedIt's not for dowels. Simply to drill holes at right angles to the piece, instead of using a pillar drill.
Ahm the Axminster one is worth a look.It's not for dowels. Simply to drill holes at right angles to the piece, instead of using a pillar drill.
I bought this lidl thing, its rubish, the resulting holes were worse than freehand.
The guides not deep enough or a slightly sloppy fit, I assume?
I never bought them but had a look at https://www.amazon.co.uk/dp/B07BVSMZ6T/ref=cm_sw_r_cp_apa_i_TiNJFb0JDY4X8?_encoding=UTF8&psc=1 made me think i should make my own.
I have a piece of MET bar (earthing terminal) that I use for that job. 6mm holes, but running them through at 8mm or 10mm doesn't take long on the drill press.I never bought them but had a look at https://www.amazon.co.uk/dp/B07BVSMZ6T/ref=cm_sw_r_cp_apa_i_TiNJFb0JDY4X8?_encoding=UTF8&psc=1 made me think i should make my own.
