Notice I didnt tell you what the programme is or even the channel.. I fear this will not be my big break..So, you're soon to be a star of stage, screen and television.Will you be signing autographs?
Notice I didnt tell you what the programme is or even the channel.. I fear this will not be my big break..![]()
Backing plate for a mechanical muncher that's being fitted to a PC800 , not a bad bit of freehand with the plasma , just welding it on to do now
First run with the new to me kemppi fastmig 500 , still messing around with settings but I don't think it will come off![]()
. So in conclusion 'it works' The plasma is a Hypertherm PM125 and Hypwtherm clearly state that this machine will pierce 25mm, so we have proven this correct. I believe that it would pierce 30mm, just need to extend the pierce delay a bit
I considered T&E at half the price but I really wanted flexible cables so I just got the proper stuff. I think I know what this clear insulation is all about too now, it's an optical illusion, it makes 2.5mm cable look like 6mm at a glance.
It's also an absolute nightmare to strip.
That's lovely.Well, 2 steam engines.
Both in need of a lot of TLC.
But ow much?
Do I strip, repair, rebuild, test?
Or do i fire up and see?
50% of both.
Mamod SP4.
A check, clean, to see if any boiler cracks and we went for it.
No majot joint leeks.
But whistle needs seals and a strip. It leaks under pressure.
But on the whole it works well.
I have spares.
This home made unit.
I had it in bits. Main steam pipe was shot.
Broken at the piston connection. Kinked and a hint of some cracks.
So I replaced it.
I also cleaned the brass up, a lot.
Put it back together. Best way to stop loosing parts, is to keep it as a unit
It works, but needs a lot of TLC.
,or at least that's what the customer said.
