hotponyshoes
- Somerset. Uk
I have got 2 types, solid copper and stranded (dont know if that's just cca?)
Generally the solid is for running through walls etc, the stranded is for making up leads to go from a wall socket to the laptop etc.
I just use the solid for everything, runs out of a hole in the roof and plugs straight into whatever.
The only leads I have made from stranded are patch leads that I want to roll up to put in a case or laptop bag.
How many meters do you need? I can probably pull a bit off the roll that's sat in my loft if you don't need masses of it
). If I go downstairs and sit next to the router there's no problem at all, fast, solid connection. My phone's been doing it too so I can rule out my laptop playing up. I downloaded a wifi analyser app which shows this when moving from my bedroom to the router;
My dad found a box at work...
