Kram
- Sussex
Are the Rectus21 fittings, same as euro air line/pcl xf?
Height is listed 420mm, is the handle easy to remove and the height without it? Im hoping it will fit where my mig used to live.
My order is still "Processing in progress", @daedalusminos did you get a tracking number? Im not good at waiting
I started off trying to braze my lathe cover, sort of worked but did not flow too well. Ill cut up some mild sheet tomorrow for more practise (and bin the rest of this galv).
what was I doing wrong, I could see the HF and hear the gas, then nothing. Turning it off and on again worked. I had a ground clamp nearby and the tip was not touching. Dirty area on the steel?
