slim_boy_fat
- Scottish Highlands
Not quite finished, but table and 4 stools set
I like the 'nesting' feature!
Finally got the tongs done, not that happy with them but I guess the first pair are never gonna be the best:
The rivet is an M8 bolt, all I had, should have been a bit longer so the other side matched better. I had it in the forge to get rid of the zink coating first. I think I could turn some nice rivet blanks on the lathe from bigger M10 bolts in the future, or just get suitable round stock and make a rivet set.
Also found some spring steel (a whole bunch, 8mm ish) and I made a chisel and punch from it.
On to the next pair of toongs soon, perhaps some hooks in between. For the next pair I will use thicker material, 10mm plate I think.
Not quite finished, but table and 4 stools set. Photos during application of clear coat. Got a few more layers to apply.
She made me happy!
Dennis
What size stock did you start with for the tongs?
OK, stop right there!
P.S. Tell her to pull those sleeves down
I just turn it sideways on the tray@Hood, aye looking good, but could you no make it swivel out towards the rear of the van, would it make easier to use ? so you could use it standing up from outside, instead of having to half crouch, bend yoursel double to get into it inside the van??
Made to measure for it turning sidewaysaye that would work fine too.... i thought it was made to measure in your usual fine fitting standards, no just any old slack equivalent ...
I spy an MX Master.Hacked off a bit at the back of the cylinder holder and managed to squeeze the cooler in behind.
Also chopped up a bit of 4" x 4" x 1/4" box then welded some 5mm plate to it and then fitted it to the Alu plate I fitted inside the van the last day. Now have a place to hold the mouse and the USB charging cable. Next job will be to sort out the laptop charger, probably just use some 3m pads to fix it to the Alu.
For changing industrial immersion heaters on a food industry application, quite restricted access hence the special shape.RJT spanners?
