hotponyshoes
- Somerset. Uk
Would any of the 3D printing members be up for printing a test object I've made up? It's a very simple 30mm cuboid bowl with a 3mm wall, looks like this:
File is attached as a .zip on this post.
Ok, it's done. What do you want to know?
X.Y.Z. 30.02, 30.04, 30.06, thickness 1.56.
Some discrepancy with the wall thickness there?
I modelled the inner subtractive cube as a ratio of the outer's length. So 0.9:1 on a 30mm length which makes 27mm. If you centre this in the outer cube and align to the top you end up with 1.5mm walls and a 3mm base
