Hi,
I just wanted to say thanks for all the great advice this forum contains
. I have used it in determining which welder to go for, setting up the welder and I am now laying my first runs on 2mm mild steel.
Here they are. It took me quite a while to get the 'bacon crackling' sound as for some reason the wire feed only needs to be at 2-3 out of 10. I started up near 6! The two welds at the bottom were at the same wire feed rate but the one in red is a higher power setting 5/8 while the other is at 4/8.
So here are my questions:
- are low wire feed speeds common on the Eland 175s? because I also noticed the wire feed seems to have a slight flat spot at low speeds
- is it better to run at the higher voltage and modify my technique to try and compensate or at the lower voltage?
- what modifications do I need to make for the scenarios above to produce better welds?
Any other tips appreciated.
. I have used it in determining which welder to go for, setting up the welder and I am now laying my first runs on 2mm mild steel.Here they are. It took me quite a while to get the 'bacon crackling' sound as for some reason the wire feed only needs to be at 2-3 out of 10. I started up near 6! The two welds at the bottom were at the same wire feed rate but the one in red is a higher power setting 5/8 while the other is at 4/8.
You should always push when you're mig welding....
