eLuSiVeMiTe
...............…………………………………… Duckhams oil! Haven't seen (or smelled) that in more than 30 years. I'd like to get a full can of it so I can use it as workshop air freshener![]()
Not familiar with it.Is it like Channel No.5 for us gearheads ?
'll self level the floors whitewash the walls and plasterboard the ceiling. Make it a useful space again
I don’t understand - how can it be useful if the lathes go?Once the lathes are gone .... Make it a useful space again
Because I don't use themI don’t understand - how can it be useful if the lathes go?
I wouldn’t be without mine, but that’s me not you! And I’m about to shift a couple of my wood butchering machines for the same reason. Good luck with selling the lathes - that Smart and Brown looks the nuts, I think they were toolroom lathes, with big headstock bearings and helical gears.Because I don't use them
Something that's unused isnt useful.
Not enough hours in the day for me to use them and has so much stuff in there it wasn't a pleasant space to spend time
Now what are you going to do instead of turning round bar down to 20% of its starting size over a period of 4 hours and then throwing it in the scrap bin and spending another 45 mins cleaning the latheBecause I don't use them
If I can slip this purchase past the wife il be enjoying one of the most iconic synths of the 80s for the next month or twoNow what are you going to do instead of turning round bar down to 20% of its starting size over a period of 4 hours and then throwing it in the scrap bin and spending another 45 mins cleaning the lathe![]()
CheersI wouldn’t be without mine, but that’s me not you! And I’m about to shift a couple of my wood butchering machines for the same reason. Good luck with selling the lathes - that Smart and Brown looks the nuts, I think they were toolroom lathes, with big headstock bearings and helical gears.
Ease come easy go.
When I have room there easy to find if you have a van and don't mind a drive
Indeed. I'd rather they went to someone hereSurely its good to list on the for sale section....at least it'll go to a good home![]()
MehIf I can slip this purchase past the wife il be enjoying one of the most iconic synths of the 80s for the next month or two
Does the plug on the soldering iron convert from a standard 13A to an old round pin, Dad had a plug like that on his for years?Had a nice score at the boot fair this morning. Two Henley Solon soldering irons - 55w and 60w, three wesco oil cans, three small hammers, a very sharp half-round file and a small hose clamp. Only 14 quid for the lot.
I had a plug like that on an extension lead at one time, I can’t recall what they were called. You slotted the square pins back in, shake the round pins out & twist then to secure them. It’s many years ago, but from what I recall they used to do 5, 15 & 13 amp. They had some name like convertaplug, they were quite popular, saved carrying adaptor leads, no doubt someone will remember the name.Does the plug on the soldering iron convert from a standard 13A to an old round pin, Dad had a plug like that on his for years?
