Hood
- Carnoustie, Scotland
I don't but if I did you would be welcome to itI wouldn't even admit to owning one of them
Is this the one you mean because your link isn't working.
https://www.ebay.co.uk/itm/Sherman-...998983?hash=item2aea81c2c7:g:igcAAOSw7ANeyrRt
If so then I think it may be cheaper on their website but if not then no, no reason not to buy via eBay.
https://weldes.co.uk/tig-acdc-gtaw-welders/62-sherman-digitig-206p-acdc-inverter-welder.html
Scroll below the welder listing and there is a pedal there.
@chrisg3103
Don't suppose you can remember what the size of the gas tube was in the Sherman can you?
Aye but is it 6 or 8mm ? Would have a look myself but working away at the moment.I had a quick look when I first got mine to see how easy it would be to replace the M10 gas connector with a Rectus 21 type coupling in the front panel (as per the UK Jasic one).
From memory ( not the most reliable ;-) ), the tube was rigid nylon and the other side of the M10 bulkhead gas connector was of the push in pneumatic type.
Colin
Was just going to say was 6 or 8mm, not much use! Can have a looksee later and see if the verynears can fit through to slots in the bottom to measure?Aye but is it 6 or 8mm ? Would have a look myself but working away at the moment.
going by the pictures, and what I'm pretty sure are m4 screw holes id go for 8mm.. but will have a look later anywayWas just going to say was 6 or 8mm, not much use! Can have a looksee later and see if the verynears can fit through to slots in the bottom to measure?
If there are slots, just looked back at my old pictures and can't even remember what the bottom panel looks likegoing by the pictures, and what I'm pretty sure are m4 screw holes id go for 8mm.. but will have a look later anyway
Think you used a barbed fitting though? Pushfit pipe is sized on outside diameter.I have 6mm and had to cleverly heat it, it would be 4mm
More or less, I was going to go for one of these types.Think you used a barbed fitting though? Pushfit pipe is sized on outside diameter.
Guessing Mr Hood is after using something like this
https://www.ebay.co.uk/itm/153224568598
But in a bulkhead fitting flavour
Aye that is a bulkhead with a hose tail.I have this one, sorry i dont know the English word for it
Yes! This! Haha! I had spotted this myself and forgot to mention it. I had to swap out the plug (I got the 17 so it had a 10/25 plug). In fact, I note you did too - have you got a 35/50 plug too?I just got the torch out to have a look at it - branded Kennedy on the torch itself, but I looked at the dinse plug and it has ‘Sherman’ moulded into the rubber shroud - exactly the same lettering style as on the side of the welder.
Yes, me too a while back when trying to get the S4 mig. I sent several emails to them without a response, but weldes have recently registered here and say that apparently weldes.de works again (but takes payment in EUR) - as does their eBay account (but I think that's more expensive)Been trying to order the 206P with pedal off Weldes but keep getting a 403 forbidden error, anyone else get this?
