I really need to get myself air fed mask. Ive had a stabbing head ace for two days now and i think its from welding or grinding fumes/ dust.
Ive looked around and read some posts but there seems to be so many different options. P3 seems to pop up alot.
Ive got a 8" extractor with a 8" flexible ducting pipe with magnets on the end which i stick 5/10 inchs away from what I'm welding.. Vented strated outside.
What kind of mask do i need? Ive got a beard. I weld mostly mild steel with a gasless welder. Grinding flapper discs. Grinding wheels. I also have a CNC machine so cut alot of sheet plywood ect out.
Im looking for something that will protect me from welding fumes. Metal wood grinding dust. i spray with rattle cans... is that a different mask all together. Im abit lost to what i need and what filters it needs.
I like the idea of the jsr infinity power caps as i can just pop it on. Ive also seen an ESAB unit which is the right sort of price at around £600... but im unsure if that will protect me against all the other work i do. Welding makes up probably only 30% of the work i need a respirator for
