angellonewolf
- bristol england
View attachment 244852 View attachment 244853 tester £3 mower free could possibly need a small patch welded![]()
View attachment 244852 View attachment 244853 tester £3 the adaptors that come with the sealy one i got fit it holing its a better quality make as its older unit mower free could possibly need a small patch welded![]()
I've got the 3500 - picked it up as a non runner a few years ago from an undertaker who used it as emergency backup.A 1980s honda generator that's done no serious work at all....
Bought as a power cut set to power a dialysis machine. Sat most of its life in the corner of a garage
Not sure that i need it... but its shiney
View attachment 244527 View attachment 244528 View attachment 244529
Or make one in aluminium sheeting pop riveting it together if you don' t mig or tig alu, or mild steel plate or better still ,,,,,the bees knees in workshop processes & materials as well as an engineering exercise cast one in 1/4 in aluminiumI’ve got an older Mountfield than that, the deck on mine is cast aluminium, the engine is a Tecumsah. We bought it second hand 25 years ago, still going strong, one new blade & a new plug, that’s all. (New plug wasn’t needed, just gave it a treat) I looked at changing it a while back, guy in garden centre said “you won’t get one as good as that unless you spend a lot of money” That one obviously hasn’t been looked after, might be worth looking around for a scrap deck.
Isn't that where the side mount grassbox goes?
Could of borrowed mine.![]()
I have a mint mountfield mower minus a good engine![]()
id let you have this one but the petrol cost would mean you could buy a new china one delivered for the same cost
I sent seller the photo. She replied that she checked them herself and they had no holes. Thats either accusing me as a liar or of damaging them. PJS tools in Sittingbourne, avoid.
Consider turning the defective ones inside out and hand stitching a repair. I've done that before with gloves, only took a few minutes and was worth the effort.I also phoned up Parweld, just to check if these were genuine or fakes. Genuine. She offered to put another pair in the post. They arrived today and no holes, and better fit than the other two. So now I have 3 pairs. The hole'y pair I will use for grinding.
Is there a zombie apocalypse that no one told me about? I’m just nipping out to the garage to put some nails in the baseball bat and sharpen the axe.
Acquired this small flypress back in May and finally got around to refurbishing it. Was gummed up but operates smoothly now. Still need to machine several adapters, to replace the hand tools for the small punch, rivet, and eyelet tools I have.A small cast iron Fly Press arrived today. Has a 2 1/4" by 6" throat. Should be easy enough to adapt my Whitney punch & dies to fit, and would be a lot easier to use than the hand tool.
The owner said it's presently set up to install brass eyelets in tarp's.
.View attachment 231480
