arther dailey
- England
Dont forget guys some brands of mig have a post flow similar to tig,some are adjustable time wise,kemmpi 200 I believe do, some are not.
Spot on, totally agree, totally random and stops flowing when it likes, I am having the same trouble with my r tech mig 180, faulty solenoid, they replaced it the next day, guess what , the replacement is faulty tooUsed an rtech 250 mig on Friday and can’t say I was overly impressed
The torch must be a dud as every now and then it keeps letting gas out like a tig being purged
The control to turn it up and down was a bit like a light switch as opposed to fine control
After all the praise of them Iv read on here I won’t be upgrading to one of them anytime soon
Thanks for that, I’mWhatever the post gas value is set at in time is how long the gas flows after the trigger has been released.
If it’s set at around 0.5 seconds which is pretty much the industry default, it should do that each and every time, if it changes, eg sometimes longer or sometimes not at all, there is an issue with the machine, most likely the Gas Solenoid.
To be fair based on some posts on more than one Facebook welding group there seems to be a spate of dodgy Gas Solenoids from them at the moment.
Usually on Mig the post gas is only adjusted when welding with much longer than standard torches (push pull) or when welding on CrNi’s
welding groups on facebook have you got the links or what they are called i will have to have a look at them?Whatever the post gas value is set at in time is how long the gas flows after the trigger has been released.
thanks just asked to join the groupThis is one group: https://www.facebook.com/groups/1598010793548453
Can't recall whether it's a private group or one anyone on Facebook can view.
If your a full time metal worker then why did you buy a modified Chinese import instead of going for a miller/lincoln/kemppi or a esab that would last you for many years..Considering I’m a full time metal worker I reckon Iv been through a few machines over the years
The thing with R Tech seems to be the customer support from what I've heard!
Not everyone drinks the same cup of tea I suppose
be careful criticising them on here, there regarded as Mecca for people that don’t know there rebranded cheapanese machines
Their plasma machines are actually pretty decent though.. but yeah i have to agree on their mig/tig machines.. its a lottery and it depends what kind of welding you need to do defo not for code work
At first I was thinking how’s he going to get that JCB out. Is that a big garage? Looks great. How do you go about something like that does the building inspector have to come and sign off the steelwork as you go or at the end like a regular build? Genuine questions, never contemplated managing or undertaking something like it myself.
OK, I have the R-Tech 250 and so far no issues with it. I should add I am a hobby welder although I learned MMA almost 40 years back at Crane Fruehauf. I bought it off the back of various reviews and these were my initial thoughts.
Like the size and portability
Like the variable control for volts and wire speed. Especially for thin car body panels. Thick stuff is less picky about such things. Operator skill also helps when you really need one of those non-existent half-settings on a transformer based machine.
Like the customer service - they were very helpful when I called up to buy it. I bought everything to start from zero so a full kit.
Don't like the torch it came with. Replaced with a 4m Binzel MB36. Much better.
Don't like the quality of the casings etc. A few sharp edges and I don't think it would take much of a beating in a commercial environment.
Definitely don't like the crappy R-Tech helmet which I bought in the kit. Can't see Jack Schitt.
Not keen on the regulator which came with it. A bit noisy and less easy to control than a decent 2 stage reg.
Other welders I have used include a Lincoln and a Migatronic, both belonging to a mate who has a garage. Both 3 phase, both built like brick ****houses, both weigh more than a small planet and both weld very well. Ups and downs to both.
I do wonder about the statement above from Tally though
Why not for code work? The welds are fine and dandy, great penetration, good consistency and would easily do the job. Coded work is about the operator skill, not the machine so much. In the right hands (not mine) this machine looks more than capable of producing work to code standard. It's not as good doing overhead though, fine in the vertical up/down and horizontal, but again, that's more about my lack of skill.
For reference, This was all done with the R-Tech 250 and their 50 amp plasma. By an amateur. This is 8mm steel I-Beam welded to 10mm end plates. 1.0mm wire and about 220 amps. Note in image 2 the penetration is fine. The last 2 images show what a crappy operator can achieve in less than ideal circumstances. Outside, mediocre skill levels, no posh jigs or table set ups etc. Just clamps, squares and grinders with the beams supported on some trestles.
So is the machine really that bad? I personally don't think so, especially for the money. How much better would it have been with a 2 grand machine? That's debatable. How much better would it have been with a professional operator? That would be much more noticeable.
The one thing I would concede is that pretty much all inverter based machines are likely to be less long-lived than a well made transformer machine. Electronics are great, but hate abuse. Personally I can live with that for the benefits of portability and storage when not in use. A professional fab shop would not be too fussed about either of those things.
All the above is my personal experience, just to add balance. I'm no expert.
View attachment 244115 View attachment 244116
View attachment 244113 View attachment 244114
