Exuptoy
- Maesteg, South Wales
Got this collected today. Starting and running on the button, unable to depress the clutch and the pedal is bent to the left I assume from over exertion trying to press it down.
Need to check if the master has any fluid and if the slave is good. Not sure if the clutch plate is stuck as it’ll go into gear without the clutch but not engage drive.
There’s also a BIG oil leak from the timing cover. Rad and mount off tomorrow to inspect it.
Transporter panels collected this evening.
