123hotchef
- Kent
38 down lighters down stairs plus the outside lighing too
not with a 10 amp breakerCan stil only draw 6amp
Though 1.5 can help with volt drop
@brightspark told me to upgrade the breaker when it was buzzing after fitting the big boy flood light outside! now i have replaced that for a LED version I could swap the MCB back to a 6A but why bother if the cable is man enoughWould naturally expect 6a breaker, hard to pull that with leds
I've got 18 1500mm singles and 3 doubles. The doubles all come on on the one switch but the rest are individually switched.a 12 and a 4gang switch Christ how many light u running![]()
the shed will have a 6A breaker anyway. The 3core was 1mmThe current capacity of the cable is going to vary depending on the installation method, it is possible to install 1.0 in such a way that it would not be protected by a 10A breaker.
The length of the run will also have an impact, which is why myself I would go for 1.5 on a 10A for a larger circuit and keep 1.0 on a 6A, and then you know you are covered whatever happens down the line.
Difference is only a couple of quid on a drum.
https://www.screwfix.com/p/lap-twin-5ft-led-batten-white-60w-5600lm/7223v what are the lap batterns like
even if u have an internal earth it needs bonding with a gland and earth tab at its sourceok so the electrics are in i didnt have a correct sized gland for the armored cable, so the Armour is not earthed ATM, Q does it need to be?
i have ordered the correct size glands so i will fit them in a few days and bond the tab to the board. thanks mate I thought the armour had to be earthedeven if u have an internal earth it needs bonding with a gland and earth tab at its source
