So I guess I'm either gonna need to buy a separate tig or another combo deal. Will definitely do more research while at workFor tig welding aluminium you are going to need an ac machine
just find some one local , and looking at your location there should be a few , with an ac dc set up , bung them a few bob , and get some steel plates cut at the same time , the curve ahead is vertical.So I guess I'm either gonna need to buy a separate tig or another combo deal. Will definitely do more research while at work
I'm trying to acquire one for my DIY projects I'm probably gonna sell the one I have and get a AC/DC onejust find some one local , and looking at your location there should be a few , with an ac dc set up , bung them a few bob , and get some steel plates cut at the same time , the curve ahead is vertical.
alloy welding is an even steeper learning curve ,, but best of luck with it all.I'm trying to acquire one for my DIY projects I'm probably gonna sell the one I have and get a AC/DC one
Ah ,, thats known as The Chinese Dragons Breath,You need to budget around £900 for a new AC/DC machine. Any less will be a cheap import that may or may not last 5 minutes before letting out the magic smoke.
That's a good idea. I believe that the more silicone hose there is under the bonnet, the faster the car goes.why not bung a bit more silicone hose over the joint , two jubilee clips , job done.
thats where the s comes from in things like ,,, Capri S Ferrari GTS ,, the Sis for silicone.That's a good idea. I believe that the more silicone hose there is under the bonnet, the faster the car goes.
Aye, I looked around back in 2005 when there was even less choice but the word was not to buy Chinese. So I bought a British AC/DC TIG (was about £1000 at the time), and it lasted fourteen years before the main transformer burned out
That said, I was able to go back to the manufacturer and get a new transformer, so it's still working. Also, I suspect it died after the temperature sensor in the wiring came adrift... fixed at the factory with hot melt glue FFS
On the face of it, those digital sets with all their slope control, balance etc. ought to be a welder's dream and if you were skilled enough to make use of it and the set itself didn't go pop in short order, it probably would be great. Yet I don't think I've read too many reports among users on here to support that.
Yes, weight and bulk can be a problem... but what if inverter sets hadn't been invented? You'd either have to pay someone else to do your welding, or just grit your teeth and get on with it. Small van, plant trailer... there are ways and means.
My AC/DC TIG lacks almost all the bells and whistles, having only gas post-flow and torch latch. However I know that the makers use the same electronics in different sets with different logos on the front and if I can get at one of those to copy (or repair) I can soon add the toys to mine... even if I can't weld for toffee![]()
manys an afternoon ive spent up a ladder with a diesel porta weld running trying to vertical up hill stick weld with the rain forming puddles on my non electronic mask ,,, and the wind blowing a gale , The good old days lol
just a thought but , if there was nothing wrong with horses ,, why do we all drive cars.
Although I've had a few nice slices of them in restaurants in Germany
