Canpoo
New Member
- Portugal
Hey there,
So I've been welding for a total of 2 days
... i know, i know, master welder.
First off, some info regarding equipment:
WELDER:
Rohr mig-200mi. (pictures attached)
Sealey MIG/7K06 Mild Steel MIG Wire 0.7kg 0.6mm A18 Grade
https://www.amazon.co.uk/gp/product/B000RA10G6/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
GAS:
Straight CO2
I've never welded before, so my knowledge comes from this forum (really appreciated) as well as YouTube.
On my first go at it, I was quite jumpy due to a healthy mix of excitement and caution. Fortunately i did record the moment so that I could be made a fool of
https://photos.app.goo.gl/AyvjDC8ZPXmVzYWQ9
After a few minutes, there was no stopping this bead runner and I was finally able to try and apply the techniques I recently acquired on the internet. Everything from gas regulation, to volts and wire speed, gun angle and push or pull techniques... all within a 20 minute timeframe
It was really an interesting experience that sparked (
) my interest in welding:
https://photos.app.goo.gl/jM9wAADiJbJ2T4VHA
This past 2 days I've been practising beads on 2mm plates with a push technique trying to make those eeeeee's (not sure what the name is).
This is the result of my first day of welding:
https://photos.app.goo.gl/rUwTKf3S6HxWsJ8W9
and my second day of welding:
https://photos.app.goo.gl/PGesSwDj4gxiQWn59
I'm running 15 cfh of straight CO2, and trying different approaches to voltage and wire. But I tend to keep the volts on level 5/6 and wire speed at about the same. I know this doesn't say much my voltage levels only show when the gun is "hot" so i'm not yet confident enought to glance at the machine while welding.
HELP
Please do critique my beads and let me know how I can improve. I find that my beads are too tall and I don't know why. I seem to be getting penetration as I can see a silhouette of the bead on the underside. Maybe i'm travelling to slow or have a higher wire speed than necessary?
Thank you all and let me know what you think of my progress,
Diogo
... i know, i know, master welder.First off, some info regarding equipment:
WELDER:
- Runs off a Standard UK Plug 240V AC
- Input Current 28a
- Output Currents: MIG 50a - 200a, MMA 20a - 200a
- Duty Cycle 60%, Transfer Efficiency over 85%
- Frequency 50Hz - 60Hz, Power Factor 0.93
- Plastic Spool with Metal Bar
- Insulation Grade F / Housing Protection Grade IP21
- Wire Specs: Speed (m/min) 2.5-13, Gauge 0.6mm - 1.0mm, Max Weight 5KG
GAS:
Straight CO2
:https://photos.app.goo.gl/AyvjDC8ZPXmVzYWQ9
) my interest in welding:https://photos.app.goo.gl/jM9wAADiJbJ2T4VHA
HELP
Diogo
