dobbslc
- Hertfordshire UK
I need a bit of advice on 2 port motorised valves!
I have a friend that has had no hot water for 2 days and his missus is going to kill him soon if it doesn't get fixed!
It's been playing up for months so he's been using the immersion heater to get hot water even though the boiler and heating are working fine
Now the immersion heater has also stopped working hence no hot water!
I had a look last night and found the immersion safety trip had popped out so reset that and it's now working fine. I've turned that off for now.
The picture below shows what he's got installed. Two cylinders paired together.
There's hot water to the top of both the valves. The valve on cylinder 1 doesn't seem to work but when I move the override lever it flows and the cylinder heats up, the valve on cylinder 2 also doesn't seem to work and has the lever missing.
I've left the valve on cylinder 1 in the override position so they are getting some hot water for now.
Questions are:
1 Could it be that both valves have failed or whatever sends them a signal has failed .
2 is it safe to leave the valve on cylinder 1 overridden until he gets a plumber out?
Thanks
Questions are:
Thanks
