Hey - egos away please everyone. This is an interesting thread which doesn't need cleaning up yet. Let's keep it like that?
There is a reason an engine works one way and a compressor another and those reasons are surely where the interest lies? I was hoping to learn something about either compressors or engines or hear from someone who has done this mod. This thread has got me thinking now. I have a few diesel engines knocking around to use as donors, would using one 4cyl diesel engine to drive a separate engine which is converted to a compressor be a better idea, most of the potential problems seem to be caused by trying to use one engine as both driver and compressor.
I have most of the stuff there to do it, but I'd like to be getting at least 80 cfm for it to be worth the effort.
80cfm is 2265lpm.
I think that's how the dive compressors mentioned above work although I think they have a lot of coolers between pistons and possibly the pistons are varying sizes?
Yup, 4 stages are common. 1st stage is normally a big high volume cylinder and getting progressively smaller with cooling between stages, but this is for high pressure compressors- 200-300 bar. for low pressure and high volume you'll need to run in parallel with as much swept volume as possible.
But if you leave a 4stroke engine as standard only half the strokes will be usefull so you would need a 2liter or 4500rpm to do it.
Am I completely missing something here, or are people over complicating this. Surely you only need a reed valve on the inlet port and block off either the spark plug hole or the exhaust port and fit another reed valve on the unblocked hole. The piston goes down and sucks air in past the reed valve on the inlet port, the piston goes up and pushes air out the other, just the same as a normal compressor. I don't get why it has to be any more complicated and certainly not to the extent that some seem to be going to
I dont think you would need to weld the piston up?
It's a fixed sweet area so what you loose in compression you gain in suction.
Yes, I am overcomplicating it. i thought that was the point of the question. Clearly a converted engine is not going to be as efficient as a compressor engine. Some of the more difficult problems beyond just getting it to work at all are issues regarding lubrication, overheating and compression ratio.
Most cylinder heads will have a squish band which can't be good for compressed air generation, it will unnecessarily heat it up for a start. If you stick oil in the intake it might even start running! If you don't stick oil in the intake, how is the cylinder going to be lubricated? Its why they (used to) put lead in the petrol.
Efficiency is the big issue for me though. unless there is a particular advantage over using a regular compressor beyond "oh I just happen to have a spare V8/VW engine I am happy to sacrifice", I don't see the attraction. You can turn a compressor motor over easily by hand, an internal combustion engine is a different matter. It is not optimised to run at the speeds you will use for air compression, my gut feeling is any engine would be too "tight" and half the energy will be lost in just driving the crankshaft.
Emergency use only would be my conclusion.
I've never seen or heard of a compressor firing itself up in all my time in the industry
