- Never Never Land
Nope, it’s just my iPhone 7 that I’ve had for a few years now. Same camera for all my pics.Are you using some kind of maginifier or fish eye lens on your camera or is it just me.
Sorry, I know about the actuator I mean the mechanism that moves the second part of the gate.The other way might be to put a bit of threaded rod, something to bolt the ram to and a couple of lock nuts on the back of the gate if you didn't want to / can't modify the end of the ram.
So I scribed them all out and then cut the sides with a jigsaw, I was going to do the back bit but it was just wrecking the blades, I got my plasma cutter out and had them all cut within a few seconds. Then ground them mostly to size and filed the rest.Really nice job and giving me lots of tips for my gate. How did you cut those slots in the flat bar? I can see the 2 vertical cuts but across the bottom? Thanks!
Haha that’s what I’m like, get an idea and then have to buy it.Plasma. Hadn’t thought of that. Nice. Another one for the list.
That’s the first on my list when I’ve done my garageYou need a milling machine in your life, Kim.![]()
Ah OK I get you now.Sorry, I know about the actuator I mean the mechanism that moves the second part of the gate.
I meant like it just looks ugly to the eye. I have some plans on how I want to do the joints but as I say I’m not sure how to work the measurements out. I’m not good enough on CAD to do itAh OK I get you now.
Do you have some ballpark dimensions (and guestimates for the weight) of the panels?
The closer you tuck the actuators and linkages into the hinge the greater the forces required. So although the "ugly" mechanism you posted is that it does have the benefit of providing extra leverage.
I did see that design but it’s no good for me as I’ve already made the hinge with standard hinges. Like on a normal door (but weld on ones)This is quite a neat design but does require some gearing for it to work so not sure how it would hold up outside:
If you send me some dimensions I can mock it up in CAD for you, probably easier to fiddle around in that than work through the maths.I’m not good enough on CAD to do it
Vaguely, I use to do a lot of trig during my apprenticeship with cutting tool tips etc but even then I still can’t remember it all as I had to do some working out not long ago. Messed it up haha.If you send me some dimensions I can mock it up in CAD for you, probably easier to fiddle around in that than work through the maths.
To be honest there's probably shortcuts to it (like I saw some simple questions in the FAAC kit) but I'd end up having to do it from first principles with some trigonometry (do you remember SOH CAH TOA from school?).
