I will dry properly paying attention to loom and connectors but I haven’t got the Kahonas to disconnect battery and then air bag connector
Ah the optional passenger foot spa! Join the club, I've a car (designed partly by BMW thinking about it!) which not only has the optional rear passenger foot spas, but the optional spare wheel jacuzzi and the in-car boot parts washer! Been round with the silicone and had the sodden parts out in the sun over the last couple of days.
Good luck tracking the leak down, they can be very annoying!
Had the airbag light thing on a VW...forgot to disconnect the battery first and unplugged the seat and airbag clips....it does work if you disconnect the battery first...you just have to remember to plug the seat back in before reconnecting the power!
btw, once the seat is unplugged and you trip the airbag code, unhooking the battery and plugging the seat in DOES NOT work. You need the special code eraser.
would love an e61....
Jp
Common problem on the E60/61. Mine had a new servo before I got it as it had filled up with water !
If the car has a sunroof also check the drains in the rear corners as it’ll fill your boot and flood the ecus!! Expensive!
Ah, the rover 75/MGZT. Yes they also suffer from this.
What are all the E numbers ? Are they like the additives in processed food !
Best thing about weemers is that you are seeing less of them on the roads now.
