Screwdriver
buying stock steel can be what is needed but if off then you need another way to make it level and straight
the drum sander is one way the other way is this way
then you need a slide to get it square and keep it straight
Why did you specifically edit this comment out of my quote?
You can pull yourself up by your bootstraps, make a machine to make a better machine etc. etc.
Not sure if it was for tits and pickles or to solve a specific problem, I suppose you could swing a bigger disc in it than on most lathes.
