Memmeddu
- Italia Sardegna
Thanks what's the difference between dark blue and straw yellowClean the metal up to a nice clean, shinny surface.
Build the fire up so you have a small, hot local bed of embers.
Clean the unburnt stuff off. So you have just abed of embers.
Lay the end into the heat, better stiff place the end so the tip is free from the embers.
Watch it.
Look for the blue temper colour to travel from the heated area to the tip.
Quench in clean cold water.
Repeat for the other side.
View attachment 213895 View attachment 213896
Ok. This is a pick axe.
But the idea is the same. You can see the way the heat has moved to the tip/
And which one is better for this application (it will hit metal)
