Gareth J
- North Cornwall
Superb is probably an understatement, so can we have a close up on the data plate? tech spec.
, I haven't got data plate as it got destroyed but I remember that lowest setting is about 16 V and 40 A and highest is 40something V and about 300A , mine does have slightly lower bottom setting so it's a bit less than 40A. I rewound primary coil of the transformer as it was partly burned which was caused by faulty power selector switch.
Here ya go - doesn't drill down into settings but interesting all the same.
What a lovely job you made of it, very nice!
Do faulty selector switches often cause the primaries to burn out, do you (or anyone else) know?
Don't know, but I do know the 12position switch on mine was really graunchy, so I had the bright idea to dismantle and rebuild. Lots of scope for messing that job up but pleased I did it.
... On the subject of switches; what's the extra switch at the top of the panel on the lower unit that's been put in? A separate on/off switch?
