Welderwayne
New Member
- Doncaster UK
Hi I've spotted this on ebay in doncaster where I'm from and its looks like a good deal £60 first the £25 to refill https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/193330486934
To good to be true or worth a punt?
I couldn't agree more. I'm pretty new to TIG welding (aluminium) and quickly found low pressure 9L pure Argon cylinders were used at an alarming rate whilst I practiced TIG welding. It cost over £200 for the three cylinders including paperwork when I returned the third cylinder against the deposit. I was advised by experienced forum members to buy a flow meter which I did. One thing I didn't do in my eagerness to start practicing was to check for gas leaks; I later found three leaks which were easily rectified. I close the cylinder valve after each session and a quick check for leaks is to look at the gauges before opening the cylinder valve; pressure should still be shown on the gauges if not there's a leak/s.
