Memmeddu
- Italia Sardegna
An arc air torch might be betterUse a larger rod holder.
What is it exactly?I suffered from regular kidney stones until I discovered a natural remedy called Quebra Pedra - google it. It cleared up my stones & I haven't had one since. I suggest you start taking it asap as it will break up existing stones making them easier to pass out.
View attachment 209685 View attachment 209686 New doors for the new workshop, 40mm box section with 11mm osb on the inside, will be insulated in the middle and waiting on some Douglas fir cladding from a local sawmill for the outside. I had to re-engineer the gate hinges with brass bushings to take out the slop, which slightly to my surprise worked really well. Just need to add a lock and come up with a security bar to span both doors for when I’m not in residence.
Fed up with lawn aerators that don't have the mass to be effective I knocked up my own using 200 x 12mm mild steel discs.
Works a treat!
Works a treat!
Er yes, it’s a work in progress. I’ve only just screwed all the nuts on so I’m aware they can be unscrewed just as quickly! All the nuts will be drilled and have tapered pins to lock them. Having said that, with a brace across the front there is no way that you could pull the door out at the bottom.I like your wishful thinking , I could get inside your building in less than a minute looking at it the way it is … weld all the nuts on the hinges or someone may well undo them & take the door off . I know you said you will have a brace bar across the doors for when you are not there but that may allow access if the nuts are undone and the bottom of the door is pulled outwards
Straps, spikes and plastic! thought I'd gone to one of those funny sites...………………………………….!
Hello Morrisman, if you like a challenge try wiring a 70's Citroen DS. Citroen used black cable throughout with coloured sleeves on the ends to distinguish. Except by now all the sleeves are beige and the insulation is falling off the cable.
Peter
No way on gods earth someone was killed with a shotgun full of shot from 175m. Not even 100m.
TVR did exactly the same thing on the early Tasmins, '79-81.
They also did things like routing all the lights current through the dip/main beam switch. The heater switches used to melt for the same reason.
Mind you, DeLorean were just as bad: their window lift motors take 9A off-load and all the current goes through the rocker switches...
What is it exactly?
How it works?
I continued taking the capsules for 3 months at full dose & 3 months at 1 per day.so I can put it on our new stainless steel mail box as we still get the local Polish postmen banging on the door to deliver a singe letter
Medics said that tea makes produce stones because high calcium oxalate content.As I said, google it!
https://www.indigo-herbs.co.uk/natural-health-guide/benefits/quebra-pedra
https://riohealth.co.uk/blogs/news/what-is-quebra-pedra
I was suffering regular bouts of kidney stones, probably 2 or 3 times a year for 3 years. The NHS couldn't do anything & couldn't find a reason for them forming. I was admitted to hospital twice in agony, all they could do is feed me morphine & wait for the 6mm stone to come out!
I heard about the quebra pedra online & tried it out.
I took the capsule form at full dose for around 6 months until I thought I was clear of stones, then cut down to one a day for 6 months.
I was also taking a mug of the tea daily, its a nice alternative to normal tea.
Probably a year or so later I felt the familiar pain in my side so I started taking the capsules & tea again. This time I passed no stones at all, the quebra pedra must have dissolved them in my kidneys!I continued taking the capsules for 3 months at full dose & 3 months at 1 per day.
That was probably 10 years ago & thankfully I have been stone free since. On one occasion I had some kidney pain so I took some capsules for a few weeks just in case.
Capsules
https://www.amazon.co.uk/Rio-Trading-Quebra-Pedra-vegicaps/dp/B0013GATP6
Teabags
https://www.amazon.co.uk/Rio-Amazon-Quebra-Pedra-Teabags/dp/B004RMGENO
If you shop around you might find it cheaper but those are the brands I used.
