The_Yellow_Ardvark
- Going Away.
Now on the 4th set of taps. If this set leaks Im going to throw it all out in the garden.
Is that a drip I see forming?
give me your full address and I will catch the sink before it hits the deck![]()
They used to shred old tyres, but I don't know if that still happens.![]()
Yes, and a bowl under it, and a mop beside it.Have you left the plug out just in case it does![]()
There used to be a place in The Forest of Dean, I think it was Lydney that scrapped old tyres. There was a yard full of them, It caught fire one day, you can imagine the result!Yes. There’s a company locally, paid to take ‘scrap’ tyres. Most lorry tyres go to Gambia. The rest get shredded, for play matting etc.
The zGermans use it in roads. No water pooling, so zero spray, better braking, quieter and harder wearing.
Old tyres are now an alternative form of energy believe it or not, replacing fossil fuels and I would imagine more lucrative than play grounds.
Link; http://www.credenv.com/products/
That’s the company I was talking about. Strangle there’s no mention of Breighton Aerodrome facility
is it an effort of a soakaway or are you putting a drain in
Two years...
But now I can wash bits of motorbike under a hot tap without taking the plates out of the sink...![]()
we can see that . to what purposeis it an effort of a soakaway or are you putting a drain in
Hello Morrisman, if you like a challenge try wiring a 70's Citroen DS. Citroen used black cable throughout with coloured sleeves on the ends to distinguish. Except by now all the sleeves are beige and the insulation is falling off the cable.
I'm re-wiring my DS Safari, originally it had four fuses and one relay. So far I'm have 16 fuses and 16 relays. I've added a lights left on buzzer, interior light delay, handbrake warning light and a rear wiper and washer. The switchgear is marginal at best so I have put relays on every switched circuit, even a relay for the starter solenoid. The ignition switch is almost £200 so I try to take the pressure off. I used British Standards wiring colour codes. As Hood said, vehicle wiring products are the business.
I must admit I am not a fan of the blue and red crimp on connectors. I expect the ones I used in my youth were cheap and nasty. I still prefer to use brass terminals, crimped and soldered.
Peter
