premmington
- Norfolk
An old fairy liquid bottle is handy to keep and dispense water
Other brands are available
The above made an old man laugh - LOL
Back to the subject:
I am a Auto Electrician - I do allot of soldering in awkward positions. Its OK with copper wires and older type solder - but new ALU strand wire and solder - you need plenty of heat/flux. You also need to get the connections you are soldering in the right "plane" - as ALU drips/runs.
Someone metioned above ALU does not have a "tinning effect" - it does - but it is harder to achieve (or impossible sometimes). Mild acid cleaning helps - (the mild acid in question is strong wheel cleaning acid to me and you). I have this acid in a small tub and apply in with a artists paintbrush - dry off with an airline - five litre can of wheel cleaning acid will last me ten+ lifetimes - one drip at a time.
ALU wires and components oxidise over time - it is this oxide that is the problem.
There is a lot on the internet - mostly from the USA - about ALU metal content repair soldering.
Grasp one wire between index and middle fingers, the other wire between thumb and ring finger. You'll find you can move the wires into position nicely. Just don't hang around with the iron, heat travels up the wire if you do.
