brightspark
- yarm stockton on tees
haven't run comp in 6 month so my mate wanted his lawnmower frame blasting . just did it in the open as haven't a shed to do it in . comp started instantly warmed it up and started . the grit I got was a bit large 1.0mm to 1.5mm it certainly cleaned it up fast but would be better suited for cleaning oil rigs up
I wouldn't do motorbike parts or wheels with it just use my smaller pot with sand for finer work
took the media valve back to bits and the grit in it was damp . decided to drill a bigger hole through it to let more grit through . dried all the grit out and the pot and sieved it. its supposed to be 1mm to 1.5mm but there was some larger than that in it so that didn't help the regulation . refilled the pot and started the comp to warm up . put helmet on and the comp cut out
refilled it and it wouldn't start . it took some doing . cracking the injector pipes and bleeding it but finaly got it running
after the mod to the grit valve and sieved grit it works perfectly ran 2- 25kg bags through it without adjustment job done not keen on lending it out to anyone else now its clean. its well used and not a dent on it and its 40 years old
