What was this post about @Hood ?Don't drink
If you have any dissimilar rods that stick wheels to Collies though...
7.5hp motor don't really know why I purchased it but it was cheap at £50 and had little use then remsoved and sat in the sun
Found a 5m roll of this in a skip: https://dedar.com/product/amoir-libre-00-amoir_/019/
Some fabric wallpaper used to tart up a Saudi Princes pad. I think it looks ghastly but at £300/sq m, I took it home anyway!
Years ago, when we had the paint stripping business, we moved workshops. The painters who had moved out, left dozens of part rolls of that type of silly expensive wallpaper. We found it great for using as floor protector when using the paint stripper.![]()
Looks like you are missing two trowels that can be very handy...…... an internal & an external right angle trowel , it's quicker to use one of them than messing about with a flat float .And cleaned up.
Have you thought to build an external sound proof locker in double block work , with double doors for access & servicing external to the place the air lines will be used in and set it on decent shock absorbers so it does not sound like you are inside a base drum every time it starts up ? One place I worked drove me potty , as I was about 30 feet from a massive 3 phase compressor that kicked in every five minutes of so through out the two days I worked there trying to concentrate on wiring up a big fire & alarm control panel .Turned out bigger than anticipated hence awaiting space in big shed
hand made in China and about £500 a roll...
In my basket along with a load more bits.Looks like you are missing two trowels that can be very handy...…... an internal & an external right angle trowel , it's quicker to use one of them than messing about with a flat float .
About ten years ago so before Banggood was known here.So, not from Banggood then....![]()
That’s the plan young man, Eventually............a timber lean-to with a sandwiched thick insulation layer.Have you thought to build an external sound proof locker in double block work , with double doors for access & servicing external to the place the air lines will be used in and set it on decent shock absorbers so it does not sound like you are inside a base drum every time it starts up ? One place I worked drove me potty , as I was about 30 feet from a massive 3 phase compressor that kicked in every five minutes of so through out the two days I worked there trying to concentrate on wiring up a big fire & alarm control panel .
I have a set of them.
Oh, wait. I don't.
They are in Southend on Sea.![]()
Because you want a rotary convertor to make 3-phase?
Dave H. (the other one)
Pictures, circuit diagram, etc, etc.I've got a 15hp rotary in bits at the moment I might build another one to sell if I get 5mins
Hmmm, " Young man " , thanks Howard . You just made my day
................. I'm 70 this year . I will post some pics and a diagram when I put it back together I got it in a box that some farmer had been playing with badly I rigged it temp on the floor and go it to prodice powerPictures, circuit diagram, etc, etc.
You know the score![]()
