The torch uses a standard 4mm nylon hose to feed the gas up to the valve block inside the torch, there is no gas solenoid in this machine.mate just a though looking inside the welder could the welder have the 4mm to 6mm adaptor, seems like on gasless there was not much weld splatter ..
Thanks
Andy
I think that he should hook some meters and write somewhere the currents/voltages curve with the various settingsShort answer, you can’t set the voltage to a specific value using the front panel display.
You will need to get the settings dialled in through trial and error, just like you would with a machine that had no display and no calibrated voltage control.
That depends on shielding gas, wire diameter and joint position.Ah I see, seeing has though you have used it successfully any chance of real life examples of what you have had it set to on the dial (1-10) for thickness of 1, 2 or 3mm plates?
What gas type and wire diameter do you intend to run?
I've put 3 rolls of gasless through mine, not done much solid wire with it.
The ammeter on mine varies with the wire feed speed knob, as far as I remember. I'll check come 5pm and I finish working
Just a dc clamp meter , connect the testing probes to the dinse connectors , you weld and someone reads the values on the meterAny links for a device like this?
