Move the ducting or move the table/workpiece, if I can't do either I'll leave the door open and wear a respirator.
I agree with above a decent air fed mask is possibly better plus its portable so always at hand
But if the garage is attached then extraction just to stop fumes into house would be a good idea.
Just casual observations im no expert!
Detached garage.
Wouldn't mind an airfed mask, much more costly though I think. Have used a Universal branded one recently which worked okay, tempted by one Esab make where the air comes in through the side or bottom of the helmet rather than the top.
I just love the smell of old underseal,oil,rust,paint 1st thing in the morning,mmmmmmmmmmmmmmmm![]()
Double check that, air coming in from the bottom sounds wrong to me for a welding visor. It’s likely to create an eddy and potentially draw in dirty air from outside.
Welding visors and similar always provide air from the top, thus giving clean air across the breathing zone and pushing away dirty air at the bottom on its way out
Think there was a nederman arm on sale here a while back at what I thought was a very good price.I will never discourage anyone taking steps to protect health, but look at how much work your planning to do, how often and then for how long.
If your a low level user, leave the door open for general ventilation. AND use a powered filtering welding shield. It will always go where you are. The extraction system your looking at probably won’t.
The proper way of doing what you want will be a Nederman type arm. I think @skotl has one in his workshop. These things are self supporting and quite expensive, require a decent amount of headroom etc.
Cost up your DIY ventilation arrangements, budget how much time you need to install then factor in the amount of faffing around that might be required to get it working. Compare this to the cost of a powered filtering visor
Here you go @Yamhon
Was being lazy and didn’t put the book on the scanner, some relevant pages photographed
This is the bible of industrial ventilation and is the bench mark standard. It’s American so units all old fashioned
View attachment 204309 View attachment 204310 View attachment 204311 View attachment 204312 View attachment 204313 View attachment 204314 View attachment 204315
Books like that excite me.
Here you go @Yamhon
It might be worth considering a cheap hot wire anemometer, or borrowing a good one - perhaps someone at college can help you out.
Weld fume is not my area, but like most extraction the problem is that expectations of how well it works outweigh actual performance. A bit like this:
The fume needs to be captured at a velocity of 0.5-1m/s. At half a duct diameter away you’re down to 30% of whatever the measurement is at the face of your ‘hood’. At one diameter away you’re at 7.5%.
Probably from the same book as Parm
I won’t go into measuring this and calculating an effective range, but suffice to say just having the hood in the vicinity of you’re working area isn’t going to do anything much, and it all comes back to the fan spec and ducting design.
Edit: I hate typing on my phone
