pressbrake1
- Essex
Forgot finished pic
Another productive day.
Finished the log store with some mesh across the bottom, and put some scrounged firewood in to dry before being cut up:
Which makes do you use?Did some MOT repairs to my van:
View attachment 204015 View attachment 204013 View attachment 204014
What do you mean by this question?Which makes do you use?
I'm Sorry, my English needs some improvementWhat do you mean by this question?
The Grinder is an Erbauer one from Screwfix & my Welder is a Clarke 150 TurboI'm Sorry, my English needs some improvement
I was meaning what brand is the grinder,and the welder?
Is that sawn up dunnage? I used to work for a haulage co in Hampshire and we often backloaded out of Sheerness steel, the dunnage there was 4” square oak, the drivers always picked up a piece or two extra for my wood burner.
. Our flat lorries seem to be doing lots of steel out of Hartlepool which needs 6x6 timbers, but we provide them, for some reason
, and it might be noticed if I go home on a Friday with a couple of them strapped to the roof of my van. One of our customers loads their product on 3' lengths of 4x4, which end up in great piles in our depot, so I make sure that any I bring back go straight into the van
. Given the job, and the ability to carry lots of loot, I should be able to keep us in firewood without paying for it, although I don't mind paying for a lump of holly at Christmas, if I can get one. The flames are truly gorgeous, looks like a methane derived flame.You sure that's not the sprouts?.... looks like a methane derived flame.
Will do for now.
Next task. Box sized to fit under the front seats. Ratchet straps pumps jump leads etc need a home and anything else that fits
View attachment 204022 View attachment 204023 View attachment 204024 View attachment 204025 View attachment 204026 View attachment 204027
A repair on a 1930s Alvis 6 cylinder engine out of a historic racing car.
Something had punched a hole in the block, and a few holes with stripped threads wanted filling up so they could be drilled and re-tapped.
But the worst job is soldering on some wedge shaped washers for an oil flow and return fitting that the client has added. No room for a weld and the client wanted the heat kept to minimum as other blocks welded in this location have been known to fail.
Trying to get this thing up to temp in the oven, then carry it into the shop in time to get the solder on before it cools too much was a challenging afternoon.
Not pretty but il be fed up with it next year and make something else to suit.Something i need to do
It's got it's seatbelt on. Going nowhereYou're going to need a cargo net over that.![]()
