I have a makita JN1601 nibbler that I bought used. I've only used it a few times & it has worked well.
I'm currently trying to cut some very thin 0.25mm box profile sheet & it's not going well. Initially it didn't want to cut it, it was just chewing it then jamming, leaving a long tongue of metal on the cut line. I think the steel was getting pushed into the die instead of cutting cleanly.
I took out the punch & sharpened it with a diamond file & that improved things as long as I was using it freehand. But if I try to use a steel guide to cut straight lines it jams up again!
This is what the punch looks like, the cutting edge is where the step is, I was thinking of putting it in the lathes 4 jaw chuck & offsetting it to try to cut a better edge on it using carbide tooling. I think its worth a try as a new punch is £23.50!
Has anyone tried this before?
This is the die, more expensive at £26!
I think the bore must be worn if the metal can get pushed in without getting cut. I'm able to file the top with a diamond file to improve the cutting edge but due to its shape it will be very hard to hold in the lathe.
Any bright ideas greatly appreciated!
