I have a makita JN1601 nibbler that I bought used. I've only used it a few times & it has worked well.
I'm currently trying to cut some very thin 0.25mm box profile sheet & it's not going well. Initially it didn't want to cut it, it was just chewing it then jamming, leaving a long tongue of metal on the cut line. I think the steel was getting pushed into the die instead of cutting cleanly.
I took out the punch & sharpened it with a diamond file & that improved things as long as I was using it freehand. But if I try to use a steel guide to cut straight lines it jams up again!
This is what the punch looks like, the cutting edge is where the step is, I was thinking of putting it in the lathes 4 jaw chuck & offsetting it to try to cut a better edge on it using carbide tooling. I think its worth a try as a new punch is £23.50!
Has anyone tried this before?
This is the die, more expensive at £26!
I think the bore must be worn if the metal can get pushed in without getting cut. I'm able to file the top with a diamond file to improve the cutting edge but due to its shape it will be very hard to hold in the lathe.
Any bright ideas greatly appreciated!
Probably buy them to have on standby.
It's impossible to follow a line, they always cut to one side, even using a straight edge as a guide! I'm hoping I still have the receipt & it's within the 3 yr warranty, they will be going back!
- I just have a decent long term memory.
