Matthew Tinker
- 93300 Aubervilliers France
I think I should warn you that they are very top heavy so it will be very difficult to lift it safely with an engine crane. If you drop the table to the bottom & add some ballast like a sandbag or 2 you might get it lifted but you really need to lift it from the top of the drill.
Ask the seller if there's a local farmer with a loader or a forklift available, it will make things so much easier. Unless you've seen one of these drills in real life you will not realise how tall & heavy they really are!
Trailer job! I confirm what Turbo says, if you take the motor off, lower the table completely (the table it's self comes off easily) and lie the drill down with the engine hoist, you might be able to lift it by re slinging it in the middle lying down so to speak!
Good Luck, Matthew
