I have seen profiles like that called "edge guard" I think, it's for things like the toilet cubical doors you see in pubs, never seen it undrilled though.
Drilled might be better if you have to make it, just spot weld through the holes onto a bit of stainless angle.
They existbut drilled.View attachment 202391
Door only has to curve on the outsideAny thoughts?
Just make a insert hinge side to mount the hinges too.
Tbh curves probably shallow enough to fit as normal but a test would be advised.
I like simple solutions. Quicker easier and cheaper.Thanks...as usual I’ve probably over-thunk it. Actually the angled one was the one that really threw me on the hinges. I’ll do some trials as you say and see if I’ve got the measurements right. Appreciate the advice.
