The type I have seen have more insert teeth and spin a lot faster (probably around 1500rpm) feed manually through a v base, I suppose as close as you would get to a router for working steel.Cant see how that machine could make a cleaner cut unless it had more teeth
Well it is a shear tool (from the look of it) I wonder if the blade needs teeth at all...
Yes as they allow it to pierce
