Ah, so switch the direction of travel too....will do.Feed it the other way.
Wow this is interesting - yes, it pulls it in. Thanks guys! However, stupid question alert - if it currently pulls it in, what’s the alternative?
I’ll get that pic or even a video tomorrow!
Make a sliding frame for grinder -couple of powerful switch magnets to attach to plate, steel rod and sliding bushes to mount grinder on.
Sorry for this, it’s just for some lads to practice a root and cap.I suppose all this depends on what the chamfer is for.
Bob
Silly question....but why would one want anything other than a smooth surface finish?Yes its a purpose designed cutter. You need a new blade. One assumes there will be a variety of cutting/shearing blades available so you pick the one that satisfies your needs for surface finish.
It might be possible to re-grind the one you have but if the serrations are noticeably more aggressive than the ones in the vid, maybe yours is set up for a more aggressive cut.
