roofman
Purveyor of fine English buckets and mops
- North West with water on 3 sides
Could be worse
50 lanes.View attachment 201814
 where is this hell hole?
 where is this hell hole?Could be worse
 where is this hell hole?Got this from a friend.
It has had some steel welded to it (not very nicely either) which must have been for a specific part. Not sure what I will do with it but...
View attachment 201848 View attachment 201849
Indeed. Why not drill and bolt. At least it's not gonna warp the part.Welded to a sine plate..
I’d drop it on his foot to start with
Drilling porcelain with a masonary bit is a loosing battle. Can literally see the bit melting away .After 2 years I had to replace a Makita Nemesis SDS+ bit
So i bought two of them both 8mm
One identical to the one I have destroyed and one longer
I can say that I would like to highly recommend Makita Nemesis
That's because after a week I owned those bits I drilled through an H beam buried in the concrete and the bit survived this abuse
After that it's being practically used to drill whatever material less than concrete .
Hardened steel
Gres
Ceramic
Rock
Not exactly designed for that but those Makita bits worked exceptionally until the last week when the 8mm bit failed aptemting to drill a gres tile
But for the price I paid... Only 4 euros it done more than what I could expect
Very satisfied with those drill bit so I bought the same exact ones
I know ,in fact that is what happened the bit got hot and it moldDrilling porcelain with a masonary bit is a loosing battle. Can literally see the bit melting away .
Took a punt on a cheap and cheerful Chinese wind deflector, as the screen is just a couple of inches too short.
It's not bad for quality, far exceeding what I expected for the price. Time will tell how well it holds up to being banged about by the wind, though.
https://www.aliexpress.com/item/32954100011.html?spm=a2g0s.9042311.0.0.55174c4doz5B3B
It wasn't him, his work bought a load of stuff from a place that closed down years ago and they were having a clear out.Welded to a sine plate..
Scrap bin?
Nice one it looks like a sine bar and is used either to measure an angle very accurately
ok go one tell me im still learning
ok to face locate any work to a given angle Sir. phewok go one tell me im still learning
I like the gauge for the air forks, it's a bit steam punk!
Frustration.
Workshop lights have been iffy for a few weeks now. But I had reasons to put it off.
This morning, only 1 tube out of 4 was working, plus none of my good spares worked.
So I got 3 x 5ft double LED batons and fitted them today.
The old lights came down, I had time and coffee.
Starting with the one good light, tube and starter I worked my way through the lot.
Up shot.
2 dead starters, 1 dead tube and now fully working old lights on the bench and no spares.
 . I'm the only slinger onsite but I'm not a climber, and all the riggers are climbers but not slingers,  so we seem to be at an impasse... Yet another night parked on the moors surrounded by sheep seems likely
