steveo3002
i think it would cost thousands to have enough gear to do what youre hoping , id go for a clean shed with a opening flap for a big fan to withdraw the fumes
The booths I've used have the inlet filters on the ceilings and extraction low down at the back of the booth this is so the air moves the mist downwards and out however unless you have a fan capable of moving masses of air you will be disappointed there is a formula online to calculate the CFM required for a given room size and it can be in the thousands
Hmm you need to think about it really because if you put it high up aswell as the Inlet the air will flow straight from inlet to outlet and not clear the lower area, use some ducting from filter up to fanAlas due to partially cladding the building with feather edge, placing the extraction fan low down won’t be possible, but thanks anyway
I’ve used this to calculate required CFM extraction
https://www.hunker.com/12387444/how-to-calculate-cfm-for-a-paint-booth-exhaust-fan
Down draught booths clear quicker than cross flow booths with the same size extractor.
A couple of pictures hope this clears things up a bit
View attachment 196205 View attachment 196206 View attachment 196207
Not sure if this will help
For the exhaust pleated filter, if the filter is going to be mounted vertically then its possible to have a channel covering the top of the filter and a support at the bottom if you then mount one above the other it just the same process.
Filter in black and frame in red
I'm toying with the idea of this ready made item for G3 type filters which might offer a better sealing https://www.justfans.co.uk/duct-mou...MI59nH1-ul5QIVi7TtCh2HoQt3EAQYBSABEgKyffD_BwEi see ...what are planning to paint in this shed?
Sorry just seen your link above
