megaflow https://www.google.co.uk/search?sou.....0..0i131j0i10.apqtfXeBXWA#spf=1570136751472yes it that sort of system much better than a tank in the loft area also gives better hot water pressure as well just needs renewing every few years though on those valves only garanteed for a couple of years
nice work there kayos but im surprised you didnt chop down the wood first and fit it to the tank area
or is it sat on a beam i cant see ?
About How much does it cost?
Is that pump pressurised or mains fed? Most new builds round here are mains fed which is ok until the water service turn the supply off. Then you have no water at all, hot or cold.![]()
Mains fed, I cant remember the last time my water was unexpectedly turned off
This job was just under £2k inc VAT
ouch, I'm getting my old vented cylinder replaced later this year, and the plumber is charging £340 for supply and fitting. its only been there for 40 years.
I suppose all this mains fed gear is OK where there is sufficient flow/pressure, not the case around here and there have been a lot of very dissatisfied folk hoodwinked into believing this is the way to go. Place we are working ATM gets a dribble at best and if anyone else uses water down the lane the water actually goes back down the pipe.
Bob
Bob
they should shell out and buy a mains cold water pressure pump then . they only come in with a drop in pressureI suppose all this mains fed gear is OK where there is sufficient flow/pressure, not the case around here and there have been a lot of very dissatisfied folk hoodwinked into believing this is the way to go. Place we are working ATM gets a dribble at best and if anyone else uses water down the lane the water actually goes back down the pipe.
Bob
they should shell out and buy a mains cold water pressure pump then . they only come in with a drop in pressure![]()
Clients had a borehole installed If you fitted one of those and it was running at the same time someone downstream opened a tap all you would pump is airClients had a borehole installed
bob
