How did you even find that video?![]()
Looking for a non advertising clip of a cold saw!
A continuously variable transmission, sometimes called a "Reeves drive", I think you get them on mopeds.it's driven by... one of those things I can't remember the name of, variable thingie... belt driven between two plates so you can change how wide the belt runs over pulley is on end to change speeds
If you put another bigger cog above the small cog you might be able to make a ratcheting lever like a arbour press. None of that walking around in circles and could be mounted nearer a wall thenGot me thinking. Just get some 10mm mild steel gears water, laser or plasma cut would be strong enough and pretty cheaper looks better than the ratchet type
Hi, Daf used a similar system in the rear axle on their cars, called it the Variomatic.
Colin
I drove a couple, but don't remember the fast in reverse bit. Many cars have a metal versian of the Variomatic, also designed by the Van Doran brothers, who were behind Daf.Couldn't they go as fast in reverse as they could going forwards?
Bought it for£45 back in 69 and towed a boat from St. Tropez to Poole, after sailing the boat from Sardinia. Interesting trip.
