DAPPH
as dyslexik as I'm daft
Thank you BEthe retail site of alibaba is aliexpress.com
Dave
Off hand do any of you guys have a recommended minimum size of SD memory card to use on our home based 3 D printers .. ? I've found a new seller ( abroad ) doing 128 mb for under £2 each
Dave , Is that on eBay , amazon or a co.uk or .com address P
awsnizzy ?
I put it in to eBay and found some expensive ones in the £7-8 range , no smaller 2 to 4 GB capacities either .
3D …..Dave
But you can get 8gb for around £2 or Branded 16gb for just over £3 from Amazon - the 128gb will either be very old stock or failed production cards. You only need 1 or 2 cards anyway?
For branded, Toshiba 16GB £3.29 each (add on items so you would need to order at the same time as something else)
https://www.amazon.co.uk/Toshiba-Mi...8JZDWNR70E6X&refRID=RCDKERPZ8JZDWNR70E6X&th=1
If you want a few, Ebuyer are cheaper 16GB cards
https://www.ebuyer.com/664443-verbatim-micro-sd-class-10-16gb-memory-card-adaptor-44082
£2.88 each and postage is £1.51 for lots of them if you wish (upto 17 of them, after this you hit free delivery)
Also do not forget you can use folders on the SD card to arrange things
Are you using these micro SD cards in an adaptor shoe ? ............…. I would have to in my Prusa I3
You are a star. Its not quite what I need however. Imagine the centre area filled in with a box that is52mm BUT is only 10mm deep....THEN another box 51mm square but is back up to 20mm deep.Not sure if this is what you want, file does need to be renamed with the extension .f3d
Its a fusion360 file with steps included
