Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
I don't think the walls will move.
My current problem is my drive from the road. I put it in 3 years ago, and over the drainage ditch next to the road I put in a plastic 40 cm industrial plastic pipe, you know black corrugated thing, back filled with hard-core etc. And then I 'concreted' over it. Ok for cars and vans. But not artic lorries and cement mixers, which reduced it to hard-core / rubble, and over months of standard car use, you get troughs and puddles.
So I'm going to wait for the last concrete floor to be poured and reattack it as it's not serious, but does pee me off. Normally I just get leftover cement slurry and pour it on, but obviously I didn't compact it enough for a 40 ton lorry. Or I should reinforce it with rebarr mesh, just more money....
or cheaper ones 22 quid ish that's probably as good just not paying for the name if its only to seal give 1st coat 50 -50 mix with water and second coat a bit thicker . it wont build up the surface just seal it
