i used it to slurry my block work before rendering and dashingI'm thinking of using SBR to do "slurry" repairs on our concrete drive; not costed it up yet though.
god that's a messy horrible job ive used oneI tried several paints which all came up with the surface before biting the bullet and grinding a couple of mm off the surface. Now I have a nice solid floor that hasn't needed another coat of paint in years and releases no dust. Important if you're into scraping as it messes up the bluing process.
Get a 9" grinder, a diamond cup wheel and make or buy a vacuum dust shroud. Hook it to a cheap hoover and grind the top down. You'll fill a rubble sack with dust for every 10 square metres grinding.
not a fast job neitherWatering can is what we use on siteWow thanks for all the suggestions guys. I’d love to paint it but feel at the moment it would be like painting a sandy beach. If I could mix up a PVA solution and apply it in a way other than brushing on to solidify it enough to allow me to paint that would be ideal.
I gues PVA is cheap and I’ve not got much to lose!
SBR mixed with pure cement & rollered on. To seal & create waterproof bonding layer.
Then a few bags of self leveling compound to smooth off.
Dry, scour then paint with epoxy.
@pandemonium123 what did you use? I found mine, a waste of time and money.
It wasn't a huge surface, I ended up using 5 litres, three coats on less than 10m2.
Still dusty. Ill paint or lino it, it is a bathroom.
Do you need a special roller to do this, i.e not a paint roller? Sounds like a good recipe for our drive, I can try.
A decent paint roller works fine, but the leveling compound prob wouldn't be suitable for a drive, re pour 4" concrete on top with expansion joints every 6m.
Get the fibre reinforced grade for good measure.
From what I have gathered from the hive mind of this forum, expansion joints are only for massive areas. My kitchen is 55m2 and back room 75m2. Doesn't need expansion joints. Might want to look at steel reinforcement mesh if you're driving vans or lorries over it.
Yes, expansion joints are just cut in from my understanding.
