It was a hard game back then. Being a ground worker and running tarmac machine gangs. Unfortunately I am suffering from the injuries I got back then. And the same for a lot of other guys. If I didn't call it a day I would most probably be in a wheelchair by the time retirement was due... i paid my way...brought my daughter up... i can now relax and enjoy what i do.... i enjoy the banter so it's all good.Sounds like you earned it, kids these days don't even know they are born, want everything without having to put the effort in and upset because their 36 hours a week takes them away from Facebook.
I know I tease, but what a fantastic way to spend your retirement.![]()
Yes mate. Am 46 now..I do a few private jobs here and there...keeps things ticking along.Retired at 40!![]()
Retired at 40!![]()
Do you enjoy it more now you have a different job.Beat me to it, I jumped ship at 41 - but started work again [doing something else] about 10 years later.![]()
Yes .I did look at that. I think my best bet is to fabricate a new stand for the motor to sit on. This will make it easier to install and remove .The original set up is the motor and all the other parts are bolted and hinged off the back panel. Its impossible to lift it.You can move the foot on that motor so the connection block is at the front, not on top. Probably still not enough room I guess?
Yer the Harrison motor is a monster .I had the task of moving it the other day...I was looking at that motor thinking that's absurdly small for this size of machine.
But then I realised I was thinking of the Harrison.![]()
Yes. I have had a good look and found a slab of 20mm. Plus some heavy motor adjustment brackets that I can cut and shut shorter.5mm plate would do but it might be a bit noisy.
Looking at the pic above I see there are two holes in the bottom edge of the cast iron backplate. I would be tempted to bolt the motor plate up to those holes, perhaps with a rubber bush or hinge block to allow adjustment. That will sit the motor foot very close to the floor to allow space for the junction box.
