123hotchef
- Kent
what do you class as upstream? the power comes via a 16amp commando plug to the dol then right now it goes to the motor no reverse switch. i need to take the feed from the dol to the switch first
to me there does not seem enough wires in the drawing4 wires plus earth, 2 for each winding - three to the motor side of the switch, one back to the incoming neutral from the isolator or whatever upstream of the switch.
Dave H. (the other one)
or burn the motor outGive it a go, worst you'll do it blow a fuse
Brown and blue to one winding, red and black to the other - I left the earth out as any damn fool nose it needs oneto me there does not seem enough wires in the drawing
Not with the right fuse you won't, the rating you want isn't 0BA Brass....or burn the motor out
ha the motor is earthed the switch wont be it is all plasticBrown and blue to one winding, red and black to the other - I left the earth out as any damn fool nose it needs one
And the blue joins the incoming blue neutral
the fuse is er there aint one its on a 16amp commando plug the dol will shut off at 5amps though
hang on i think i get it now so only the red and black get reversed when the switched is reveresed?
so I can just use some wago connectors on the motor winding wires to extend the wires to the reverse switchExactly!
I try to make it look pro - I've a few feet spare of 4 plus earth Syflex (with the steel loose braid between cable and outer jacket) if it's any use to you?so I can just use some wago connectors on the motor winding wires to extend the wires to the reverse switch
that would be great, TBH you will not see the cable unless you open the door as it will all be behind the stand apart from a few inchesI try to make it look pro - I've a few feet spare of 4 plus earth Syflex (with the steel loose braid between cable and outer jacket) if it's any use to you?
It's a catch plate. Used for driving the workpiece when turning between centres.
Using a lathe dog.
