Do you think it could have fell out in the shipping?..lol
What I don't see is the main inverter transformer. I would have thought that, even for a high frequency switching supply, for a machine of this power rating it would be a noticeable item.
Hmmm.....
Still waiting for the pics Hugh! How are you getting on with it? I'm thinking of getting a plasma cutter and one of the things I want to cut on a current project is a hole (to take a bolt) through a piece of 30mm round bar, would yours manage this d'ya think? Can you make a cut from both sides if it doesn't cut through and what sort of a mess would cutting a say 15-18mm hole make?On mine, the main switch mode transormers are in the middle of the main heatsink so is cooled by the flow of air. Mine is very similar but I will post some pictures tomorrow.
Hugh
Quite an ask that. I take it the workpiece is in situ and cannot be drilled? Alex
Generally you wouldn't look to go in from either side with gas/plasma. It makes an awfy mess if you don't go through all the way because the molten metal has to go somewhere. I'f you've not gone through the piece that means back in the general direction of you!
And for 30mm you'd need a big old plasma cutter!
